Author Topic: boost problem ?  (Read 1532 times)
Offline james2
  • No scammers please.
boost problem ?
« on: 13 September 2015, 16:06 »
Hi , not been on here much.
Last night i booted the car up the mad mile. It pulls strong then pop pop, and sort of holds back. It did it in second and third gear on full throttle. Any ideas.
 I thought i my have hit the rev limiter as i was not looking at it.   :huh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline pickles
  • Next!!!
Re: boost problem ?
« Reply #1 on: 21 September 2015, 18:17 »
get it scanned m8 and see if theres any fault codes.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Dalo Harkin
Re: boost problem ?
« Reply #2 on: 21 September 2015, 20:35 »
MAF or coils, does it pop all the time now or only under boost? Disconnect the MAF first and see if it improves if not reconnect the MAF and check the coils
