Author Topic: Steamy cabin  (Read 2720 times)
Offline Cerialkarpins
Steamy cabin
« on: 08 September 2015, 21:22 »
No im not an avid fan of dogging.
A while back i mentioned about a leaking sunroof.  Well a little update for anyone with a similar problem. Turns out it wasnt the seals it was the drainaway hose. My problem was with  the one on drivers side A pillar. Fairly simple. Remove airbag clip. Undo t20 bolt. Take off fuse box cap (near steering wheel) then pull away at the A pillar cover ( be careful there is an airbag). Follow the tube down. I pulled mine out then put it back in (wheeeeey) put all back together. No more steamy car and the rank chemicly/mold smell its disapearing.
Hope this helps anyone with a similar problem ( the tubes aparently go 2 all corners of the car. Some times the connection from on the sunroof to the tubes can leak also)
Offline wakey
Re: Steamy cabin
« Reply #1 on: 02 December 2015, 08:20 »
Another easy rout is to blow compressed air through the drain holes.
Also a dirty cabin filter can cause condensation
MK7 Golf R. MK5 Golf Ed.30
