Author Topic: Stainless manifold on a MK3 GTI 16v going to do anything?  (Read 4567 times)
Offline Foreveryoungaus16v
Re: Stainless manifold on a MK3 GTI 16v going to do anything?
« Reply #10 on: 09 September 2015, 09:22 »
Yeah it certainly helps if you can do it yourself! Lol Might as well chsnge all bearings etc in the gearbox as well if pulling it apart. I think Hotgolf quoted about £400 plus for a full rebuild and final drive with you supplying the gearbox. Then you got costs of fitting etc so it all adds up. Being mechanically minded would certainly save you a fortune but if you don't know what you are doing get someone who knows what they are doing in that department
As for porting and polishing the cylinder head a specialist company like TSR would charge about £700 including fitment. Thst is without the cams and port matching the manifold.  Hence why I would rather go down for 1.8T route. I have my suspension,  brakes, wheels and bodywork up to top spec now so it's just a case of saving for a big conversion. In the meantime am quite happy with my 163 bhp :smiley:
« Last Edit: 09 September 2015, 09:28 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
Offline LR5V
« Reply #11 on: 09 September 2015, 19:47 »
I had one of these on my ABF for a few months, it did fit.
One of big issues was how it fits onto the CAT -the manifold uses a ring & the CAT has a flange -its also a smaller bore than original.
The other issue was the lack of flexi connection, I have hockey pucked the front mount and had a new gearbox mount fitted -despite the engine hardly moving around it kept snapping bolts at the down pipe to the CAT. didnt have the time to look at it properly, took it to a local tyre tyre depot, they put even larger bolts on than standard, everything was good for a week until I down changed and the manifold snapped at the collector.
Reverted back to original manifold, much smoother easier to rev, it has a flexi connection & more power - not had a problem of bolts snapping since.
I suspect these are actually a Mk2 16v manifolds
VW BUSH
« Reply #12 on: 09 September 2015, 23:19 »
Stainless is just a b!tch to fit. most of the time its the wrong type of material and crappy welding that lets go.
get what you pay for.
Offline general_piffle
« Reply #13 on: 11 September 2015, 00:07 »
Hmmm, thanks for the feedback guys, am going to can this idea.Cheers.
Offline spikenipple
« Reply #14 on: 11 September 2015, 11:27 »
I've lightened a few flywheels for people on here, although I'm not sure if anyone has actually fitted them yet!!
Give me a shout if you want one done. I have two stock flywheels here at the mo, waiting to be lightened.
I can either sell direct or exchange for your stock one.
