Author Topic: Help!! Golf Mk4 probs  (Read 1804 times)
Offline Audidave
« on: 07 September 2015, 22:08 »
Hi all, I recently bought a mk4 1.6 2003 golf as a second car,
It had been sat for about six months without moving,
I have stripped & cleaned the brakes + new pads but the pedal goes to the floor & the red stop lights flashes then the engine goes berserk. Can't find a vacum leak anywhere & I also changed the master cylinder as I was convinced that was the issue.
Any advice would be much appreciated
Dave
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Help!! Golf Mk4 probs
« Reply #1 on: 07 September 2015, 22:30 »
if the fluid has run dry you will need to find someone with vag com to prime the ABS unit with fluid again
Offline Audidave
« Reply #2 on: 08 September 2015, 10:41 »
I had this problem before there was anything removed, the pedal is fine with the engine off, if I disconnect the vacum pipe at the throttle body & plug it then start the engine the brakes are fine.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 08 September 2015, 21:04 »
Checked the one way valve?
Offline Audidave
« Reply #4 on: 08 September 2015, 21:17 »
Is that the one on the vacum pipe?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 09 September 2015, 07:05 »
Yeah that's the one. You've also got one going to the servo from the other side of the inlet
Offline Audidave
« Reply #6 on: 09 September 2015, 08:20 »
Where exactly is that one? Cheers
