Author Topic: Grrrrr...God damn car  (Read 1852 times)
AvwgolfA
« on: 23 September 2005, 20:18 »
After whistling my way down to the stealership to unzip and hand over a kidney for a new engine speed sensor  £149.16.. :shocked: i returned home and started to take the car apart AGAIN! :angry: 1 hour later it's fitted and ready to go. :cool:
Guess what..?
IT'S STILL FOOKED.. :laugh: :laugh: :cry:
Hoping the code reader arrives in the morning.. :undecided:
Dizzy cap and timing going to play with these tomorrow.. :undecided: :evil: :laugh:
Pass the big hammer... :evil:
Offline Overseer
Re: Grrrrr...God damn car
« Reply #1 on: 23 September 2005, 23:17 »
 :cry:
AvwgolfA
« Reply #2 on: 24 September 2005, 16:48 »
Saturday update.. :laugh: :laugh:
Been playing around today and i discovered that the coil  is only pushing 9v down towards the dizz when you turn the car over not even enough juice to make a difference or a spark tbh.. basically the power out from the coil is kaput and i think the secondary windings have gone under load maybe i shouldn't have carted 20 x25kg bags of gravel around in the boat for 2 trips and all the concrete out of the garden to the skips as well...still looked lowered at the time.... :laugh: :laugh: :laugh:
Prepares to sell left lung to vw for a new coil.. :laugh:
« Last Edit: 24 September 2005, 16:58 by Count-Von »
Dinky
« Reply #3 on: 24 September 2005, 16:50 »
haven a clue wot ya gan on about count..but..hope ya fix it! :laugh: :laugh:
Dinx :kiss:
Offline golfpro
  • If in doubt, pay someone else to do it!
« Reply #4 on: 25 September 2005, 08:09 »
arh, someone else is just as confused as me!
good luck with it all wayne! rather u than me mate!
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
AvwgolfA
« Reply #5 on: 27 September 2005, 09:11 »
Woo hoo it's fixed sort of, well at least it starts now just need 2 new tyres on from my bowels of the counts garden shed.. :laugh:
Offline Y I GTI
« Reply #6 on: 27 September 2005, 11:52 »
So was the coil causing the car to cut out wen it started getting warm and wen left to cool down wud it start straight away am having these problems wiv mine wen ya spray wd40 on coil car runs fine for few hrs.changed coil once but coil is smaller than the one a took off. :undecided:
AvwgolfA
« Reply #7 on: 27 September 2005, 14:13 »
Neither sir shedalot just went stone dead after i turned it off down the skips maybe he wanted to stay.. :laugh: :sad: had to be towed home bty the AA turns out that the coil and the crank sensor went at the same time just worked the old boy to death i suppose.. :laugh:
I would take the coil off and clean all the electrical components and make sure the earth wire is clean as well stick it back on the car and try it out maybe the coil you put on the car is breaking down under load after a being used for a while the coil i have on the car now came off a 1996 16v mk3 but if the one you have put on is smaller i would either do a parts search and check out the part numbers or ring vw spares and ask them to run a check against the parts list.
mix
« Reply #8 on: 27 September 2005, 18:56 »
:laugh:
