Author Topic: VCDS Long Coding for 5F Module  (Read 10213 times)
Offline spooooook
« on: 28 August 2015, 12:59 »
Could anyone with a VCDS cable who owns a Mark 7 GTI/GTD with Discover Pro and Dynaudio soundpack please assist me with the long coding for their 5F (Information Electrical) module?
Many thanks,
S.
Offline itavaltalainen
Re: VCDS Long Coding for 5F Module
« Reply #1 on: 28 August 2015, 18:23 »
You're probably better off asking in the VCDS or VCP Forum....
I can give you the coding for my 5F, but I only have discover media and no dynaudio.
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    040 0421
   Serial number:
   Coding: 02730201FF00000011111201002800031F0102860100010045
   Shop #: WSC
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD:
   VCID:
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number:
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 AB    HW: -----------
   Component:  ECE 2015/16  --- 0051
   Serial number:
Offline spooooook
« Reply #2 on: 28 August 2015, 20:42 »
   Serial number:
   Shop #: WSC
   ROD:
   VCID:
   Serial number:
   Serial number:
Thanks very much, but it's the Dynaudio coding differences that I'm really interested in.
« Reply #3 on: 29 August 2015, 11:31 »
What do you want to do exactly?
Offline spooooook
« Reply #4 on: 29 August 2015, 12:46 »
I'm trying to retrofit Dynaudio and the main stumbling block is coding of the Discover Pro unit. There are no label files on VCDS to identify the correct Bits/Bytes to change in the 5F module, therefore the only way to work it out is to compare the differences between the long coding string of my current non-Dynaudio car and one with it factory fitted.
« Reply #5 on: 29 August 2015, 14:21 »
Can you post a scan of your current coding?
Will see if there is a way to find out what the coding is.... I have VCP it coding may be documented on there if I connect it to my car.
Offline spooooook
« Reply #6 on: 29 August 2015, 15:27 »
   Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
   Component: MU-H-ND-EU    H43 0376
   Coding: 02730001FF00000011111201000800031F0207D601000100D7
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1A3124461DB34BEEB8-804E
   Subsystem 1 - Part No SW: 5G0 919 606     HW: 5G0 919 606
   Component: ABT_High  H61 0030
Offline p3asa
« Reply #7 on: 29 August 2015, 20:03 »
I have DynAudio and Sat Nav Pro
   Part No SW: 5G0 035 020 C    HW: 5G0 035 020
   Component: MU-H-ND-EU    H40 0290
   Serial number: A458D0E7509209
   Coding: 027300010000000011111202000800001F0202F60100010057
   ROD:
   VCID:
Offline spooooook
« Reply #8 on: 29 August 2015, 22:17 »
   ROD:
   VCID:
Thanks p3asa. Could I also trouble you for the log details of the Media Player/subsystems (the unit in the glovebox)?
Regards,
S.
Offline p3asa
« Reply #9 on: 29 August 2015, 22:20 »
Where do I find that?
