Author Topic: Water stains  (Read 2723 times)
Offline Quicksilver
Water stains
« on: 27 August 2015, 16:59 »
I live in a hard water area and if I wash the whole car then it dries leaving round stains before I can dry it myself with a leather. Consequently, I have to wash and dry the car a section at a time - roof and windows, front end, sides etc. This makes it a long process and of course as I wash one section I splash water on sections that I have already washed and dried.
Does anyone have any suggestions?
Graham
Offline AcousticInertia
Re: Water stains
« Reply #1 on: 28 August 2015, 13:31 »
Personally I dispensed with a leather years ago. Replaced it with a "Wooly Mammoth" microfibre towel. The thing is amazing. Will dry your entire car in one go without needing to wring it out. Also much less likely to scratch if u use the pat dry method.
Offline Booth11
Re: Water stains
« Reply #2 on: 28 August 2015, 14:21 »
I sympathise with you totally!  I have the same problem - very hard water and even though I use good quality drying towels, in sunny weather, I have to do the same as you and wash, rinse and dry the car in sections to avoid water marks.  It's a major PITA, and water marks are a nightmare to get out.  I managed to polish the worst out but it's an uphill battle.
As suggested, ditch the leather and invest in some good towels, Always make the final rinse one with an open ended hose, to reduce standing water on the car.  Additionally try a rinse/ drying aid - such as DoDo Juice Time to Dry - it's basically a quick detailing spray you spray on the car after rinsing which will dissipate the water further and then soak up what's left with a micro fibre drying towel.
For a more extreme remedy you could invest in a dryer such as Master Blaster but not cheap and you'll need quite a powerful one to dry whole car.
I'm so fed up with hard water that I'm about to buy one of these, which attaches to your hose and filters the water.  Expensive but I've had enough of water spots!
http://www.raceglaze.co.uk/race-glaze/400-litre-0ppm-car-washing-filter/
« Last Edit: 28 August 2015, 14:42 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
