Author Topic: Orange gear linkage bush replacement  (Read 2035 times)
Offline philstar
  • ...life is all about creating memories...
« on: 24 August 2015, 11:34 »
Hi guys I am rebuilding the gear linkage and have just replaced the big orange bush in the engine bay however I am not sure I have got it in all the way, I can't find any pictures so can anyone confirm that this is in correctly?
https://goo.gl/photos/C8K572QT4MjDvbGP7
1988 Atlas Grey VW Golf Mk2 16V GTi [F748 FGT]
Rebuilt: fuel pump housing | suspension | gear linkage | aluminium radiator
Offline philstar
Re: Orange gear linkage bush replacement
« Reply #1 on: 24 August 2015, 12:30 »
The answer is NO.
The bush should be further in so only a small bit protrudes equally on either side, the bush should also be fairly loose inside the housing. I drilled out the rivets and put the bush in properly:
https://goo.gl/photos/VEg7UaiNBkwWheDG8
Offline oakgreener
« Reply #2 on: 24 August 2015, 15:42 »
Spot on.That's what I had to do
