Golf mk5
H7 Bulbs help needed
Topic: H7 Bulbs help needed (Read 2581 times)
jaylufc17
Just got here
20 August 2015, 07:17 »
Currently have the following installed into my car however they required resistors when i installed them
http://www.ebay.co.uk/itm/361324859573?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
got the resistors of the guy however the wires are too long for both the main and the dipped beam housing.
has anyone got any bright white cree bulbs? (dont have to be cree but as long as they are white, bright and no resistor/small wire for the resistor)
the main beam i may be able to get away with a resistor wire as there is space to hide it however the dipped beam not sure as to how you would place a resistor onto the bulb as the bulb directly goes onto the screw thing which seals it in...
proper pain this is as my MOT is due soon and just want the light to go on my dashboard
fyi my 501 which work fine are
http://www.ebay.co.uk/itm/131317065961?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
my h11 are the following and have resistors (no error message for these now)
http://www.ebay.co.uk/itm/231538867635?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
hope this makes sense
th3_f15t
Re: H7 Bulbs help needed
25 August 2015, 11:24 »
These any good to you:
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2008/p/car-parts/car-electrics-and-car-lighting/lighting1/car-bulb/?48177022W&1&f849e79480f87100bfafda883ab54d570b1d206b&000384
Used them on my GTI, the look spot on.
Moving over to Flickr, sorry for the broken picture links!
Golf mk5
