Author Topic: Fog lights question  (Read 2654 times)
Offline ImIMK3
Fog lights question
« on: 18 August 2015, 22:30 »
Hello all. I recently purchased some new bumper indicators for my mk3 which came with a set of fog lights. Wanted to know how I could get these hooked up, there doesn't seem to be any existing wiring for it currently to set it up?
Offline RichardBaronGolf
Re: Fog lights question
« Reply #1 on: 19 August 2015, 13:27 »
You'd have to buy the loom for them I believe! Just a quick look on Ebay reviled:
http://www.ebay.co.uk/itm/VW-mk3-Golf-headlight-foglight-wiring-loom-GTI-breaking-for-spares-/252057142514?hash=item3aafc6c4f2
Guy has everything you need for it if you read the description :)
Offline itavaltalainen
« Reply #2 on: 20 August 2015, 09:43 »
You can make loom at home.
You need two plugs, a spade connector, eye connector for gnd and bit of 1 or 1.5 mm2 wire in two colours.
Posted on here once or twice what to do and some photos as well. Can't find easily with my mobile on holiday though.
Offline snozan
« Reply #3 on: 20 August 2015, 18:32 »
If you saearch you will find the loom. Every MK3 has the same harness. Only difference between the models are that some are connected and some dont. But they all have the same
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
« Reply #4 on: 03 September 2015, 21:29 »
Offline SimonG
« Reply #5 on: 06 September 2015, 10:28 »
Is the wiring for fog lights already present in the main loom from the fuse box to the circular connector at the front in all cars?
I know that on my 16V the wiring was already there for range adjustment, I just had to sort the loom from the circular connector to the lights.
  Mk3 Anniversary GTI 16V, Mk2 GTI
« Reply #6 on: 06 September 2015, 12:27 »
Yes.
