Author Topic: HELP HELP HELP PLEEEEEEEEEEEEEEEASE!!  (Read 2442 times)
Offline Sim454
« on: 18 August 2015, 20:16 »
Hi all my names Si, first post...
I've had nothing but problems with my AUM not boosting right and being sooo slow, I'm at wits end!  So thought it's time I asked the experts.
Cut a long story short, after replacing and repairing boost and breather pipes, the car is finally boosting standard up to 0.6 bar and hold's at 0.5.  But there just ain't any quickness, pull, sharp throw back in your seat when the turbo kicks in, nothing, it's just flat!!  That ain't normal is it?  I'm thinking I have a fuelling problem or air sensor maybe O2 sensor that's faulty?
What do you guys think?  I'm so fed up now, all my spare time has been fixing her, not driving her :cry:
There's no fault codes thrown.
Si
Offline barrym381
Re: HELP HELP HELP PLEEEEEEEEEEEEEEEASE!!
« Reply #1 on: 18 August 2015, 23:23 »
don't expect 150bhp to throw you back in your seat  :smiley: try a map from r-tech it will make it a bit better
Offline Rhyso
« Reply #2 on: 19 August 2015, 00:04 »
Standard 1.8T = crap  :grin:
Modified 1.8T = money pit  :laugh:
Welcomes to the forum  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 19 August 2015, 18:02 »
Amen to that
Anyways it sounds like you need to make sure it's running healthy anyway, there's a few sensors that can cause problems and they're probably a bit old now.
Like the other guys said though it's nowhere near as quick as the older style RS Turbos or Renault 5 turbos as the boost is more linear and drive-able.
Offline Sim454
« Reply #4 on: 20 August 2015, 17:59 »
Hey guys
Cheers for ya replys.  I think that's what I've concluded, they are just slow as!  Hence why everyone seems to be mapping them.  I had an Uno Turbo many years ago and I think I'm constantly comparing it to that.
What sensors should I replace?  Water Temp and O2 sensor?
Could the wastegate need tightening?  It's pretty easy to move.
Thanks
Si
Offline Mr_Orange
« Reply #5 on: 20 August 2015, 22:17 »
Sensor wise the MAF and IAT could perhaps do with a clean. N75 could be playing up. It can get expensive chucking random new parts at it.out
Do you know anyone local to you with a good runner to swap and trial any parts before spending out?
Build thread clicky
Offline itavaltalainen
« Reply #6 on: 23 August 2015, 16:19 »
You can check temp and O2 sensor. No need to replace unless diagnosed faulty.
Offline Sim454
« Reply #7 on: 30 August 2015, 14:22 »
I bought a remapped ecu and plugged it in with risk! Car runs fine and boosts very well indeed. The problem was that it was a standard Golf :grin:
It's fun to drive now but I do have a flat spot at 3500rpm in every gear. I think I'm not getting enough fuel so I'm replacing fuel filter and fuel pump uprated.
Si
Offline shaft69
« Reply #8 on: 30 August 2015, 14:27 »
Most def money pit but worth it must have put easy £4k into my engine but damn it fast. :)
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
