Golf mk4
Wazzzer
p1296 keeps coming back
Topic: p1296 keeps coming back (Read 3683 times)
yougy
16 August 2015, 16:11 »
iv a golf mk4 18 turbo AUQ 180bhp, p1296 keeps coming back bringing engine light on, changed thermostat and water temp sender any ideas out there
thats fooked it
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: p1296 keeps coming back
16 August 2015, 17:54 »
Maybe wiring issue, read more here:http://wiki.ross-tech.com/wiki/index.php/17704/P1296/004758
What program did you use to her fault codes? P errors tend to be OBD2....
Worth checking actual readback with VCDS.
yougy
16 August 2015, 18:14 »
iv a D900 hand scanner and vcds lite basic and both say the same?
thats fooked it
itavaltalainen
16 August 2015, 23:48 »
What's the story if you look at measuring blocks rather than fault codes with VCDS?
yougy
18 August 2015, 19:14 »
it says on vcds lite
1 fault found
17704-error in mapped cooling system(check temp sensor and thermostat)
p1296-35-00-
any ideas as stated iv changed both and still it comes back
thats fooked it
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
19 August 2015, 18:03 »
try wiring next mate
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
yougy
Reply #6 on:
19 August 2015, 18:29 »
wot wiring dude
thats fooked it
itavaltalainen
Reply #7 on:
20 August 2015, 09:48 »
If you have VCDS lite you can look at measuring blocks, not merely fault codes....
What wiring? Obviously the wiring between ECU and temp sender.
Golf mk4
Wazzzer
