Author Topic: Vagcom, need a second opinion on a log  (Read 5116 times)
Offline pickles
  • Next!!!
« on: 15 August 2015, 17:46 »
can anyone on here  who reads and understand vag com logs give me a 2nd opinion, think my MAF is on the way out, just need confirmation.
« Last Edit: 16 August 2015, 14:18 by pickles »
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Vagcom, need a second opinion on a log
« Reply #2 on: 16 August 2015, 22:27 »
Hard to tell as it doesn't look like any of the runs are a full throttle run...
Do it again at full throttle until redline if you can
Offline pickles
  • Next!!!
« Reply #3 on: 16 August 2015, 22:41 »
thats about as high as i get without loosing boost :(, arnt the numbers low tho.
 done another log but again couldnt get past 6000 rpm, also logged my timing.
changed my n75 for an old c type i had lying around so logs are with the old valve in, how do the n75 numbers look.
http://s000.tinyupload.com/index.php?file_id=63780478044559150883
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 17 August 2015, 20:58 »
can you check your throttle angle mate?
Agreed it looks like it's taking an age to get anywhere, N75 seems to drop off too
Offline pickles
  • Next!!!
« Reply #5 on: 17 August 2015, 22:29 »
its 1.3* , i think this is within range, gotta new MAF coming, (doesnt go wrong if its not that, think the one thats in just now is over a year old so not bad  :grin:,) if that dont fix it,  then its N75 time, whats ppls thoughts on the H version, hit n miss ?, failing that ill be looking at the wastegate actuator, fingers crossed it aint that cos that would mean dropping the turbo to change it :(
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 17 August 2015, 22:37 »
You don't need to take the turbo right out for that :wink:
If I take the take the car out for a spin I'll get some logs for you have a look through for reference. Might even have one on the computer....
Offline pickles
  • Next!!!
« Reply #7 on: 17 August 2015, 22:46 »
that would be great if you could m8 thanks, can you change the actuator without having to remove the manifold, heard its a right coont.
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 17 August 2015, 22:56 »
manifold has to come off unfortunately
These might help, they're old but might be good for a comparison
I think they were all from the same run...
Offline pickles
  • Next!!!
« Reply #9 on: 17 August 2015, 22:57 »
starting to think its defo  more a weak actuator or n75 now tbh after reading up a bit on it, my boost gauge shows me peaking at 10 psi and then dropping suddenly, surely this would be the n75 not being able to hold the wastegate shut at that pressure and just opening.
Mapped
Nearly S3 time  :)
