Author Topic: Tyre tread depth  (Read 7329 times)
Offline Sootchucker
Tyre tread depth
« on: 11 August 2015, 13:30 »
Can anyone with a new Golf fitted with 18" Bridgestone Potenza S001 tyres let me know how much tread there is in a new tyre please ?
Call me sad, but I've been monitoring the wear over the last 8000 miles or so, but forget to check the tread depth when new to see how much (as a % of the whole) the tyres have worn.
Many thanks.
Offline matchboy
Re: Tyre tread depth
« Reply #1 on: 11 August 2015, 14:23 »
I think its 6mm - I've just had a service (12K miles) and my front tyres are at 4mm, one at the back is 5mm, the other at 6mm.  I could be completely wrong however!
I was actually a little disappointed as the front two on my GTI were bald at 18k miiles - clearly not driving hard enough  :laugh:
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
Offline mcmaddy
« Reply #2 on: 11 August 2015, 15:04 »
Should be 7-8mm on a brand new tyre.
Offline Sootchucker
« Reply #3 on: 11 August 2015, 15:30 »
Thanks guys. 8mm is about what I thought.
Currently have a minimum of 4mm (outside of Nearside front) with an average depth of around 4.5mm all round after 16,500 miles. I just wondering how far I will get before than get down to about 2.5mm (which is when I will change them). 20k maybe ?
Offline matchboy
« Reply #4 on: 11 August 2015, 16:11 »
That makes sense, as no way I'd have not lost any tread in 12k miles - sorry to the OP  :laugh:
Audi RS5 2018
Offline itavaltalainen
« Reply #5 on: 11 August 2015, 16:12 »
Simple maths should give you the answer.... 16k5 miles / 3.5mm = 4k7 miles/mm.... 2mm left (left till 2.5mm remain) x 4k7 = 9k4 miles left.
Offline monkeyhanger
« Reply #6 on: 11 August 2015, 17:51 »
Not quite that simple, as the tyres wear down, the rolling radius and circumference come down slightly. Based on 18" wheels and a 90mm sidewall (225/40), and adding either 2.5mm tread or 8mm tread gives you a 65.32cm or 64.22cm diameter, and a 1.6% difference in rolling circumference between 8mm and 2.5mm tread depth. Your wheels will be spinning a little faster to maintain the same speed and therefore wearing a little quicker. But 1.6%....who cares?  :tongue:
Offline Sootchucker
« Reply #7 on: 11 August 2015, 18:10 »
Knew we could rely on you MH for the technical answer  :grin: :grin:
Offline caprigreen
« Reply #8 on: 11 August 2015, 20:27 »
Great stuff but you do need to get out more Sherlock  :smiley:
64 plate VW Golf GTI PP Pure white
1991 VW Golf GTI 8v Silver, 30k miles
Offline caprigreen
« Reply #9 on: 11 August 2015, 20:33 »
I remember seeing an 11 month old GTI at the dealers , it had covered 8k miles and the tyres were just legal. I test drove it and ragged it , looks like everyone else did the same  :cool: The way I drive could be looking at 20k  :grin:
