Author Topic: TB clean = mpg shock  (Read 1428 times)
Offline Mr_Orange
« on: 04 August 2015, 20:41 »
Its been a few years since I cleaned the tb.  Plenty of excuses ....  :whistle:
It started to surge slightly and was bogging down when pulling away, so I bit the bullet and took it off for a clean.  It wasn't so bad, but enough gunk came out with the spray and a wipe around.  I put it all back to together and did an alignment.  All good  :wink:
I drove it to work and back last couple of days and mpg has gone up from high 20s / 30 ish on the 10 mile commute, to 37 and then 38+!  I'd kind of got used to the lower mpg, but to see a 25% increase from that alone is pure mental!
Give it a go, you might be surprised!  :cool:
Build thread clicky
Offline Scott D
Re: TB clean = mpg shock
« Reply #1 on: 04 August 2015, 22:41 »
Reminded me need do this on mine as doubt has been touched since leaving factory.
Did on my previous golf after fitting a catch can which made a big difference to MPG well worth doing
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
