Author Topic: Carbonio  (Read 2060 times)
Offline Dalo Harkin
Carbonio
« on: 04 August 2015, 08:35 »
Anyone running a Carbonio all year round?
It does look very hidden in the bumper so I doubt any water would splash up but I will be avoiding massive puddles!
Offline Scott D
Re: Carbonio
« Reply #1 on: 04 August 2015, 22:46 »
Not a fan....
Had one for a couple of years and the filter got dirty within months. No gains after back to back MAF logging with open cone.
Piece of mind not having to worry about hydrolocking either
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Dalo Harkin
Re: Carbonio
« Reply #2 on: 05 August 2015, 08:38 »
well here is the dilemma, I was running the pipercross panel filter in the standard airbox with the DSG mods and I did prefer it but the TIP seems to be slightly bent in the middle when I use airbox which would obviously restrict flow.
I think I'm just going to go back to the airbox and try and sort a new TIP ( I remember how much of a nightmare it was to fit so not on any rush  :laugh:)
Offline Scott D
Re: Carbonio
« Reply #3 on: 07 August 2015, 00:40 »
If your sorting a new TIP go for a supersize, they are a ball ache to fit but worth the hassle and fit with standard air box.
Offline Dalo Harkin
Re: Carbonio
« Reply #4 on: 07 August 2015, 16:59 »
I remember you fitting yours didn't it take like 4 hours!  :shocked:
Offline Scott D
Re: Carbonio
« Reply #5 on: 08 August 2015, 19:57 »
only took an hour second time fitting one
trick is to bend the coolant pipe slightly, still a biatch to fit though  :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Carbonio
« Reply #6 on: 08 August 2015, 23:13 »
yep, thought I was gonna snap that pipe lol
