Author Topic: Golf aum oil press stop motor  (Read 2176 times)
Offline mike1990
« on: 02 August 2015, 15:56 »
This alert came out about 2 month ago after 2k revs. I checked oil and it was up to level but bubbling. A day later it went away, yesterday it came on again but this time it wouldn't go even when I went below 2k revs, now soon as I start engine and move away about 5 seconds later the alert comes back also does it whilst idling too. The engine is making a loud noise seems to be coming from top of engine. I guess this is the oil pick up pipe blocked? Will I be able to just take the sump off clean the pick up pipe and put new oil in and the problem will be sorted?
Offline Dalo Harkin
Re: Golf aum oil press stop motor
« Reply #1 on: 05 August 2015, 13:04 »
I wouldn't clean it I would just replace the oil pickup pipe there about £12 from the stealers if I remember right.
Getting the sump off can be a bit of a pain though.
You'll need new oil (5 litres I think)
new Pickup pipe
Sealant for the sump
and a new oil sump nut
All in all should take about an hour and use a 10mm socket on the 18 or so long nuts that hold the sump on not an allen key in the middle like I did once  :grin: be warned though there are some hidden bolts near where the sump connect to the gearbox and these are a proper PITA
Offline JMK3
« Reply #2 on: 05 August 2015, 17:16 »
best off gettin some ball ended allen keys for the 4 bolts that are partially hidden
Offline mike1990
« Reply #3 on: 06 August 2015, 03:07 »
Just read it, yes thats exactly what I did lol. Replaced pick up pipe, whilst I was at it I gave it a service, new spark plugs, air filter, oil filter, fuel filter, 5 litres of castrol oil.
Problem now is there is a slight estitation on acceleration, hunts a little bit on idle.. I'm replacing the PCV hose tomorrow, see if that helps.
Offline Dalo Harkin
« Reply #4 on: 06 August 2015, 08:49 »
have you scanned it for faults?
If its hunting on idle, I'd test the MAF and clean the throttle body
Offline mike1990
« Reply #5 on: 06 August 2015, 10:13 »
There's always been on a fault with the MAF, signal too low. However, I cleaned the throttle body and now it started doing this. I did realign it afterwards.
Offline Dalo Harkin
« Reply #6 on: 06 August 2015, 12:09 »
Have you replaced the MAF then?
