Author Topic: Help - MK3 1997 Steering  (Read 1932 times)
Offline Tahi
« on: 01 August 2015, 14:16 »
Hi everyone, I have a problem with the steering in my MK3 1997 GTI.
It only happens after driving long distances, occasionally when I slow down and turn the corner, the steering locks up. I've checked the power steering fluid and it's not low. I'm not too mechanically minded so if anyone could give me any input that would be great.
Also, I read that VW power steering fluid is real particular, and because I don't know what was used by the previous owner, could it be possible that it's caused by using the wrong fluid? And if so is it possible that it happens turning one side?
Offline madmanmart
Re: Help - MK3 1997 Steering
« Reply #1 on: 03 August 2015, 17:23 »
Check the belt tension, it could be slipping.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
VW BUSH
« Reply #2 on: 03 August 2015, 20:35 »
Check the tension as mmm said, if you can splash 8 quid on a new belt it's a no brainer.
most cars are on their original pulleys which wear out as they are friction drives, new belts can still slip prematurely as the belt drives from the v flanks and if it bottoms out then it will slip pretty quick especially when wet or cold.
VW want a fortune for the pulleys so I just bought new pas belts once a year lol
Offline Foreveryoungaus16v
« Reply #3 on: 04 August 2015, 06:12 »
It'll be the belt slipping. Get a new belt (or tighten the current one if it's in good nick) and all will be fine.
163 BHP (TSR POWER RUN)
