Golf mk6
Snoopy
Rear door won't open
Topic: Rear door won't open (Read 2527 times)
bcarlin
GTI forum regular
31 July 2015, 14:28 »
Hi guys have any of you experience of a rear passenger door not opening. It's locked shut. The car has been sitting for about 3 weeks not getting used. Is there anything to check or a fuse etc ?
bcarlin
GTI forum regular
Re: Rear door won't open
31 July 2015, 19:50 »
Got the door card off. Mechanism sounds like it's working but nothing happening.now it gets worse, the cable for the electric window has came loose and not on the drum properly. Think something fell out of the door card when I drilled the rivet out. Anyone had there door in bits ? The door still isn't opening !
mustard
Here all the time
Mk7 R
31 July 2015, 20:34 »
Had a similar problem with my Touran, passenger door would not always open, could hear the click when using the key and the internal button. Unfortunately I needed a complete new lock, fortunately warranty paid.
Snoopy
Moderator
Serious forum addict
Geoff.
31 July 2015, 20:53 »
Its a common issue with vw products. It defaults to deadlocked when it fails.
Ive not done one on a mk6 but plenty of mk4s, passats and our two SEATs.
Search the net for the wiring to the lock diagram.
Disconnect it from the door controller.
Then connect the unlock wires to a constant 12v+ signal (cordless battery drill is my fav) while its connected and trying to unlock keep trying the exterior door handle thats normally enough to unlock it and open the door. Then disconnect the power of cause.
Remove the lock (now you can get at the screws). Disassemble it. Resolder all the joints on the PCB and check the cogs also clean the microswitches. (Its nornally dry joints and dirty microswitches)
If thats above your capability replace the lock unit with a new or secondhand one.
Last Edit: 31 July 2015, 20:57 by Snoopy
Mk6 GTI & Mk1 GTI
34 years of GTI ownership.
bcarlin
GTI forum regular
31 July 2015, 21:03 »
Thanks for the Help. What If I can't get it open with the wires direct on. What's the other option ?
As for the metal wire that goes to the window regulator I've no idea how there is slack on it now and it feels loose. It keeps on jamming now
bcarlin
GTI forum regular
01 August 2015, 07:18 »
Anyone know what pins are for the deadlock so I can get the door open
Snoopy
Moderator
Geoff.
Reply #6 on:
01 August 2015, 07:42 »
If the door lock motor is still running then 99% of the time it will in my experience open.
if it does not sadly due to the removal screws iirc been on the door side like other vws you have to hammer and chissel the plastic lock mechanism from inside the door cavity and destroy it to get the deadlock pin to unlock. Infact the destruction way is the way most people do it rather than the way I do it. Lots of info on that on the net.
Mk6 GTI & Mk1 GTI
bcarlin
GTI forum regular
Reply #7 on:
06 August 2015, 18:38 »
Door now fixed,new lock and window regulator. Now when I lock or unlock the doors there is a beep as if it's the horn or alarm ? Can I stop this. It's not the full on horn just a beep then a beep beep when locking
joe6
Reply #8 on:
07 August 2015, 15:21 »
I set my golf to beep on locking. Needed to code it using VCDS so assume you need to do the same to remove the beep?
Mk6 GTI Carbon Grey, 2010 Bluetooth and voice fitted, a few VCDS mods still a comfortable family car. Red Scirocco 2011 twin charger stage 1 - enjoyable drive now gone. White 2016 Polo GTI (roller skate on steroids) replaced with an Indium Grey 2019 7.5 GTI PP.
bcarlin
GTI forum regular
Reply #9 on:
13 August 2015, 18:07 »
Still beeping so I can only assume the guy had to program the door latch and has turned it on by mistake. Anyway £340 later the door is opening !!!!
Golf mk6
Snoopy
