Author Topic: Retro Fitting LED Back Lights?  (Read 4210 times)
Offline TurboTrev
« on: 30 July 2015, 15:49 »
Is there a guide anywhere on site explaining how to retro fit GTI/GTD led back lights - I've tried searching but couldn't find one?  Or even better, is there anyone in the north east of England who could do it for me!  Thanks.
Offline mcmaddy
Re: Retro Fitting LED Back Lights?
« Reply #1 on: 01 August 2015, 22:45 »
What are you fitting them too? Another mk7?
Offline TurboTrev
« Reply #2 on: 02 August 2015, 14:47 »
Wife's MK7 1.4TSI R-Line.
Offline cheechm
« Reply #3 on: 02 August 2015, 16:05 »
Is it really worth the cash?
Offline remlapeel
« Reply #4 on: 02 August 2015, 18:39 »
Wouldn't you prefer to fit the smoked R rear lights?
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline mcmaddy
« Reply #5 on: 03 August 2015, 08:41 »
Is it not just plug and play?
Offline remlapeel
« Reply #6 on: 03 August 2015, 09:21 »
I was thinking the same, surely it's like replacing the spotlights in your house with LEDs. I didn't need VCDS to get those to work in my house lol
Offline dv52
« Reply #7 on: 03 August 2015, 10:31 »
remlapeel: Hi.
Not sure how familiar you are with the Leuchte channels in the BCM, but each exterior light on a mk7 is controlled by these channels (there are 19 x channels for each lamp). The Leuchte channel set for the reversing lights are
Leuchte28RFL LC11- Right Reversing lamp
Leuchte29RFL RA64 - Left Reversing Lamp
Each of the Leuchte channels-sets starts off with a "Lasttyp" setting which tells the car the kind of light that is installed (Lasttyp means "Load Type" in English). For plain ordinary incandescent lamps the setting for the first of these 19 x channel is something like 9 - allgemeine Glühlampe 27W; auch H15 . But for LED lamps, there are other settings that are used. I have shown the 46 x possible settings for the Lasttyp channels in the table below:
Also, for incandescent lamps, it is possible to illuminate the light up-to a setting of "!00" (in the Dimmwert channel), but for LED lamps, this number increases up to "127". What does all this mean to someone thinking of upgrading? Well the short answer is - not much at all. Depending on the LED lamps, you will most likely be able to simply plug-and-play the fitting (without any error messages from the CAN bus). But, to get the most out of a properly functioning LED lamp, I suspect that there will be some change that should be made to the two Leuchte channel sets that I have indicated above.
Don
« Last Edit: 03 August 2015, 10:34 by dv52 »
103TSI Highline ROW (my13)
Offline TurboTrev
« Reply #8 on: 03 August 2015, 18:45 »
Done some googling and it needs extra wires for the lights to work properly, but no vcds coding is required.
Offline Jimble
  • Moderator
« Reply #9 on: 03 August 2015, 21:50 »
