Author Topic: V reg 1.6 auto cuts out all the time  (Read 3016 times)
Offline Slacker The Pinstriper
« on: 30 July 2015, 13:25 »
This has been a problem on my wife's car for nearly 2 years now.
We've had it plugged in numerous times with no fault detected.
It's terrible on fuel also.
It can cut out at any moment, after starting, under heavy breaking, turning whilst breaking or just cutting out dead!!
Any ideas?
Offline itavaltalainen
Re: V reg 1.6 auto cuts out all the time
« Reply #1 on: 30 July 2015, 14:20 »
What's the engine code?
Does she have all her keys and some more on the keychain with the ignition key?
« Reply #2 on: 01 August 2015, 19:07 »
Engine code is AE
And there is only another key (one for Central locking one for ignition) then another small key
« Reply #3 on: 01 August 2015, 19:41 »
AE is not the engine code me thinks... they are 3 letters on the mk4.
My money would be on ignition switch (the electrical part at the back of ignition lock).
Why do you have two different keys for the same car?
« Reply #4 on: 02 August 2015, 08:34 »
AEH
Two keys as said above as central locking went and for a quick cheap fix put a skoda lock in the door
« Reply #5 on: 02 August 2015, 09:53 »
When it cuts out do any of the lights on dash come up?
What did you use to check for fault codes?
« Reply #6 on: 07 August 2015, 10:25 »
Sorry for late reply the battery light comes on when it cuts out.
I dong know what they used I assumed it would have been vagcom??
« Reply #7 on: 07 August 2015, 19:06 »
Ignition switch I would suspect.
« Reply #8 on: 10 August 2015, 19:35 »
Thanks mate i'yll look into it
