Author Topic: Mark3 GTI 8v cutting out still!!!  (Read 1584 times)
Offline Y I GTI
« on: 22 September 2005, 18:47 »
tried almost everything, relays,coil,leads,dissie cap, rotar arm,plug,leads, n its still cutting out tried 2 lots ov relays, cleaned throttle housing,seems to run for about 10 mins n starts cutting out, sounds like its chokin wen it starts ,changed the fuel filter near petrol tankn dun the lot n its still playing up has anyone new ideas that might sort this out,its really starting to become a pain the behind!!!!
Offline Vagman69
Re: Mark3 GTI 8v cutting out still!!!
« Reply #1 on: 10 November 2005, 17:39 »
Make sure all relays are firmly in place. I've been having cutting out probsat junctions particul when braking gently. Took everybody's advice and went diving to check ECU relay etc. 56 was loose. Pushed em in and problem solved.  going to try her out again this eve to see if this was no fluke!!
Offline cs98sss4
« Reply #2 on: 11 December 2005, 14:22 »
Check knock sensor try getting a user with VAG-COM hooked up whilst running, this might be the cause of the problem.
Golf MK3 16V ABF "Anniversary"
Offline adyh
« Reply #3 on: 14 December 2005, 12:58 »
If you live near london , i have VAG-COM .
Offline lisa30
« Reply #4 on: 14 December 2005, 14:14 »
Mine was all so a pain in the rear so i paid for a test to see whats wrong had the throttle adjusted 2 new ht leads ansd  had a new distribtor fitted and so far so good
failin that dunno??
[img]http://img.photobucket.com/albums/v714/lisa30/car.jpg
