Author Topic: Tracking done for new tyres?  (Read 3104 times)
Offline mcmaddy
« on: 27 July 2015, 18:05 »
When people get new tyres fitted do you always get the tracking done as well? I can't remember the last time I had tracking done on a car and was thinking do you need to these days. I phoned the dealer who fitted my tyres to get the rears rebalanced as I can feel a vibration under my seats at 75 and upwards. Receptionist said I might need to book it in for a full wheel alignment check if it wasn't done when the tyres were fitted. What do others do and will the dealer do alignment properly?
Offline monkeyhanger
Re: Tracking done for new tyres?
« Reply #1 on: 27 July 2015, 18:19 »
Chris: the dealer will do a full 4 wheel alignment properly and charge you an arm and a leg for it. Expect to pay something daft like £140, if your tyres have worn evenly then I wouldn't bother, but it is £36.99 at your local ATS when booked on line. Mine was done for the ACC "fix" under warranty, but they won't tell me how far out (if out at all) my wheels and/or ACC sensor was, and how much adjustment was required (if any). My warranty work invoice does not state prices charged to VW for the work.
You probably just need a rebalance.
Offline Booth11
« Reply #2 on: 27 July 2015, 18:24 »
I generally try to get a full 4 wheel alignment check (on a Hunter machine) done after every winter, what with all the pot holes etc.  A proper check can be done from anywhere between £40-£90 depending on where you get it done.  I think it's worth it.  If I was having a new set of tyres I'd definitely get one done.  If I get B'stones on my R and end up swapping them for PSS then I'll get the alignment done too.
This might help.  You can find your nearest Hunter centre.
http://www.alignmycar.co.uk/wheel-alignment-all-you-need-to-know/
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline phil_790
« Reply #3 on: 27 July 2015, 19:18 »
Hi all,
Back in April when I had my tyres changed at a national tyre company, it was noted that they had worn unevenly, so I had them do the wheel alignment (at a much lower price than my local dealer), but didn't tell me that they didn't have the parameters for a mk7 golf, but told me the mk6 wasn't too different from a mk7! So just be careful when getting it done anywhere other than a VW dealer. Needless to say I got a full refund and got it done properly at my local dealer for about £100 for full 4 wheel alignment.
They were a little bit out, the garage did give me a full copy of the report with the before and after values of every parameter.
Cheers,
Phil
Offline Rhyso
« Reply #4 on: 27 July 2015, 19:31 »
Follow the link Booth gave you and you won't go wrong  :smiley:
I have my car tracked twice a year; when my winter wheels go on and when they come back off
Last couple of years its only ever needed a tiny adjustment and my tyres have worn evenly
Keeping an eye on your tyre pressures will help too   :wink:
Offline Booth11
« Reply #5 on: 27 July 2015, 22:02 »
This too.
Annual alignment check and monthly tyre pressure check should keep everything on track (pardon the pun).  At my service a couple weeks back the tyres were wearing very evenly so combination of the above does keep things in check.
I've got one of these and it's proved to be accurate against the proper tyre pressure machines.  Just more convenient.
http://www.amazon.co.uk/Michelin-Digital-Tyre-Pressure-Gauge/dp/B000V5F0XQ/ref=sr_1_1/276-4746636-5241734?ie=UTF8&qid=1438030566&sr=8-1&keywords=michelin+tyre+pressure+guage
« Last Edit: 27 July 2015, 22:04 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline mcmaddy
« Reply #6 on: 28 July 2015, 07:39 »
Booth I've got exactly the same gauge  :smiley: I check my tyres every week if I can and I'm sure my old tyres wore evenly. I haven't got a hunter alignment centre in Sunderland and not that keen to go to revolution in Gateshead either.
Offline Booth11
« Reply #7 on: 28 July 2015, 09:09 »
Yeah the Michelin tyre guage is very good. :smiley:
If you can't find a Hunter place local to you, there must be somewhere nearby that offers comparable 4 wheel optical, laser alignment system, measuring within the parameters similar to the Hunter system, i.e. measurements from minimum of 12 angles, before and after readouts, etc?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
