Author Topic: Front mount intercooler  (Read 3303 times)
Offline turbokid23
« on: 20 July 2015, 12:55 »
After being away for 2 years am back and can't find a decent intercooler for my aum, do I go twin one side or one each side? Also it's only going to be stage two on a k03s, also want it to fit nice but don't want the big ££££ tag
Offline nzgolfgti15
Re: Front mount intercooler
« Reply #1 on: 26 July 2015, 22:58 »
I have a twin side it uses less piping which means less lag. Cheers
Offline shaft69
« Reply #2 on: 29 July 2015, 22:29 »
Welly cooler with alloy pipe work and silicone hoses of ebay cost about £250 all in.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Dalo Harkin
« Reply #3 on: 31 July 2015, 08:37 »
I'm running a stage 2 K03s and used all the TT/S3 tubing (inlet manifold is the opposite way round) reduces the piping.
Still get a bit of lag but its not too bad at all.
Offline turbokid23
« Reply #4 on: 03 September 2015, 17:05 »
Cheers guys going to look at getting 1 in couple of weeks after I fit new turbo
Offline LR5V
« Reply #5 on: 03 September 2015, 17:56 »
just watch the pipe sizes as not all are the same. twin passes seem to come in 2" and 2.5".
I dont think I need to tell you what one will give you more joy!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 04 September 2015, 09:16 »
I use the THS twin pass as it was the best fitting cooler out there at the time with a standard bumper
Offline OSR
« Reply #7 on: 15 October 2015, 12:42 »
As above, I've had a THS intercooler fitted for a couple of years now - very neat solution and a quality bit of kit that comes with a full set of comprehensive instructions too! You do need to do a little bit of bumper trimming, I managed to get mine about 90% but gave up at the time and haven't been bothered to revisit since. I really should make the effort ho-hum.
