Author Topic: Fault codes no lights on...  (Read 3880 times)
Offline ajmoir36
« on: 17 July 2015, 18:15 »
Just been out for a routine scan and have a couple of fault codes, that won't clear. Oddly though there is no light on.
 Address 01: Engine (J623-CJXC)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091D00322466050B3004
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001003
   ROD: EV_ECM20TFS0205G0906259E_VW37.rod
   VCID: 3065EB906BD754A1DEF-8065
1 Fault Found:
16452 - Implausible Data Received from ESP Control Module
          U0416 00 [047] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 5778 km
                    Date: 2015.06.12
                    Time: 07:22:52
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 62444000000173
   Coding: 01FA93A15421296E037B070241C96980C92A94C0E08296F7F84250F8C208
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 4689AD48F953EA11143-8013
1 Fault Found:
4235 - Vacuum sensor
          C10A3 29 [137] - Signal Implausible
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 109
                    Mileage: 5778 km
                    Date: 2015.06.12
                    Time: 07:22:50
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline itavaltalainen
Re: Fault codes no lights on...
« Reply #1 on: 17 July 2015, 18:30 »
Where did you try to delete?
In Autoscan or in the individual control modules?
Offline ajmoir36
« Reply #2 on: 17 July 2015, 19:01 »
Both
