Author Topic: Aum gti temprature rising  (Read 1656 times)
Offline PacalDnB
« on: 14 July 2015, 19:12 »
Hi all, when im driving the golf the temp goes straight to 90 but if i go above 60 or put my foot down thegauge rises quite quick, but when i ease of throttle it drops, is this the temprature sensor or something more serious?
"It aint dubbin' if it aint rubbin"
Offline itavaltalainen
Re: Aum gti temprature rising
« Reply #1 on: 14 July 2015, 20:43 »
Temp sensor is a dual unit, if the one for dash and engine read very differently it should through the MIL (gets picked up 90%).
I would suspect your thermostat is not opening fully (check if radiator gets hot) or the impeller has separated from it's shaft in the water pump, or the impeller is missing wings....
Offline Mr_Orange
« Reply #2 on: 20 July 2015, 18:54 »
Update in this?
I too suspect the water pump :'(
Build thread clicky
Offline PacalDnB
« Reply #3 on: 17 September 2015, 11:10 »
Sorry for late reply, it was infact the water pump that had failed, only after changing radiator, thurmostat did it becaome apparent. cheers for the help guys!
