Author Topic: Soundaktor post BW22 cars  (Read 6990 times)
Offline Snooze
Re: Soundaktor post BW22 cars
« Reply #10 on: 20 August 2015, 08:08 »
Get that soundaktor unplugged! Best thing I ever did.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Jackie Treehorn
« Reply #11 on: 20 August 2015, 18:14 »
I noticed that while Eco makes the car much more quiet its was only when I unplugged it that I noticed it was still in the background, even in Eco mode.  Needless to say 15min later I had a heavy little speaker to stick in the shed for posterity.  Hopefully Eco on BW22 will turn if off completely but I wouldn't be too sure.
« Last Edit: 21 August 2015, 10:14 by Jackie Treehorn »
Offline Bungleaio
« Reply #12 on: 22 August 2015, 13:56 »
Does this mean the it will be selectable on the GTI's too or is it just R's?
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
Offline NeilH
« Reply #13 on: 25 August 2015, 12:49 »
Hi,
I can't see anything on my post BW22 GTI. I've got a VCDS cable so I set it to 0% in there, however, changing driving modes my well alter the value. I'll try and confirm that.
Neil.
Offline NeilH
« Reply #14 on: 25 August 2015, 18:20 »
Right. I've had a browse but can't find anything linking it to a menu option, only thing I can think is that it's buried deep in the 09 Adaptions list and that's one I've only got half a map for as the laptop run out of power...
I'll pull a full map later in the week and have another go.
Neil.
Offline Bungleaio
« Reply #15 on: 25 August 2015, 18:55 »
Cool thanks for looking into this for me.
Offline Websta24
« Reply #16 on: 26 August 2015, 14:58 »
Hi,
Neil.
When you select the driving mode, select "individual" in the top right hand corner it gives you an option to customise and then a lit...things like Steering, Engine, ACC, Cornering lights, Air Con....you can basicly combine Sport/Eco/Normal on specific things...Steering - Sport, Engine Noise in Cabin - Eco etc etc
You cannot adjust the volume
Offline NeilH
« Reply #17 on: 26 August 2015, 19:52 »
Hi,
With VCDS you can set the volume in the A9 Controller as a percentage. When I did the change, I was in ECO mode and it was set to 100%, so I reduced it to 0% and that appears to work OK (ie, it stays quiet no matter what mode you select). Some of the guys on the R forum with post BW22 cars appear to have a option to allow adjustment from the config menu so I'm hoping to find that in the 09 controller adaptations list and expose it with VCDS - I just need to get a full map of the controller to try and suss it out.
Neil.
Offline NeilH
« Reply #18 on: 27 August 2015, 13:07 »
I've searched through the Central Electronics module but I can't find anything obvious that's would open up a menu option for the underlying volume of SoundAktor. If it is available, then it's well hidden...
There are lots of options for multicoloured lighting though - if only they fitted multi-coloured LEDs in the GTI then we could have a bit more individuality....
Neil.
