Author Topic: 2.0gti 8v 1997 ABS sensors  (Read 1639 times)
Offline oldgit
« on: 21 September 2005, 18:48 »
Hi All,
        Anybody know of a quick way of telling which abs wheel sensor is faulty perhaps without taking each one off and swapping it till the warning light goes out. :sad:
Offline kr1s77
Re: 2.0gti 8v 1997 ABS sensors
« Reply #1 on: 21 September 2005, 21:45 »
 the way i found out is by getting it a guy to read the faults, a garage normally charges about £30 - £60 to read faults.
ASV 1.9 TDI 110
Offline adyh
« Reply #2 on: 22 September 2005, 09:52 »
The proper way is to get the faults read , as it may not be a sensor at all .
Offline Dom Mk3
  • Insert wit here
« Reply #3 on: 22 September 2005, 12:21 »
where abouts are you? should be someone somewhere close who has vag-com?
Offline blue_concept
« Reply #4 on: 22 September 2005, 12:22 »
i had the same problem. took it to a garage and they decided to take them off, but in doing so they snapped both of them. so had to have them replaced in the end.
the guy says they are really hard to get off without breaking, safest way is a test.
Offline adyh
« Reply #5 on: 22 September 2005, 14:32 »
If you are near london , i can read them for you  .
