Author Topic: Xenons always on???  (Read 3274 times)
Offline Dipesh2031
  • Options bae?
Xenons always on???
« on: 05 July 2015, 13:54 »
Hi,
This is my first car with xenons, and even when the light is switched off, the xenons are on full blast? why is this? is there something wrong? I cant turn them off unless I switch to side lights.
MK6 GTi - Black - DSG - 18' Monza shadow - Luxury Pack - Convenience pack - Park assist - Xenons - RNS510 - Adaptive chassis control - Dynaudio - Bluetooth - Reverse camera - front/rear sensors --mods-- Evoms Intake - Eurojet/stasis Turboback Catless 3" exhaust
Offline Booth11
Re: Xenons always on???
« Reply #1 on: 05 July 2015, 14:17 »
Just to clarify, are you talking about the main Xenons or the DRL's (daytime running lights)?  If it's the main lights are you saying that even with the switch in the OFF position they are on?  They should be off with the switch in this position.   If the switch is at AUTO position they may be on or off depending on weather the light sensor determines is required based on the outside light conditions.
If it's DRL's then on later models they are always on and cannot be turned off without VCDS.  On earlier models you could turn them off via the indicator stalk.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline SRGTD
« Reply #2 on: 05 July 2015, 14:41 »
Hi Dipesh. The early mk6 xenons didn't used to have the LED 'fairy light' DRL's and the xenon dipped beam acted as the DRL. Not certain when the LED DRL's were first introduced, but if your car pre-dates this, then this would explain why your dipped beam headlights will be on permanently.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Dipesh2031
  • Options bae?
« Reply #3 on: 05 July 2015, 14:42 »
It's a 2009 model, so no DRL's
when the main headlight switch is off the xenon dipped beam stays on, when they are on Auto it is also always on and in dipped beam mode they are also on, only on side light mode are they off, very odd...
Offline Booth11
« Reply #4 on: 05 July 2015, 15:30 »
Sounds like that's the early style DRL then.  If you want to turn them off, as they are xenon I think you need VCDS as stated in this thread http://www.golfgtiforum.co.uk/index.php?topic=187595.0. I think only the early halogens DRLs could be disabled via the indicator stalk.
« Last Edit: 05 July 2015, 15:35 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline GTI2014
« Reply #5 on: 05 July 2015, 22:05 »
Hi Dipesh,
As per above link, the Xenons can be turned off using VCDS by changing "DRL via low beam" option - co-incidentally made this change a few days ago when making the change to remove the errors for the new LED tails (thanks to top bloke, Andy, for helping me out with this!)
Offline Obbzi
« Reply #6 on: 06 July 2015, 23:19 »
This has always bugged me. I have xenons too and can't turn them off
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline Dipesh2031
  • Options bae?
« Reply #7 on: 07 July 2015, 03:37 »
ah I thought this was the case, I want my DRLS to be the side lights as I think these look quite cool, especially when I put super bright white LED's in there  :grin:
Offline dubber36
« Reply #8 on: 07 July 2015, 08:05 »
You can code it with VCDS to do that, but you'll have your tail lights on as well. I know you do at the moment, but I think it looks a bit odd.
