Author Topic: Light fault -making me scratch my head  (Read 3169 times)
Offline Misterp
« on: 03 July 2015, 20:44 »
Turned the car on this evening to find a fault that read 'Fault: vehicle Lighting'  and a yellow triangle wth an exclamation mark in it. walked around the car no lights are out.
Truly at a loss as to what it could be. I don't have vcds so may have to check it in to vw.
Has anyone expereinced such a fault.
Golf GTD mk7 DSG pearl black - collected 25 September 2013.
Re: Light fault -making me scratch my head
« Reply #1 on: 03 July 2015, 22:33 »
Try running it through a few ignition cycles to see if the 'fault' clears itself.
Offline KyleB
« Reply #2 on: 03 July 2015, 23:44 »
Checked the bulbs with the steering wheel turned? Not a cornering light bulb gone is it?
Offline Misterp
« Reply #3 on: 04 July 2015, 01:11 »
Tried both. Still the same I did a quick google search and it threw up a few things. I may take the Philips static h7 out and replace with stick see if that clears it as that is the only none standard exterior light bulb I have fitted
Offline monsta
« Reply #4 on: 13 September 2020, 15:09 »
Resurrected an old thread but mine has just started with this error. Did you ever get it sorted?
