Author Topic: VRS alloys on Mk4?  (Read 3722 times)
Offline YBTurbo
VRS alloys on Mk4?
« on: 20 June 2015, 22:30 »
Hi,
Bought a set of Fabia VRS alloys earlier,
Same as these,
There 16x65J ET37, Assume these are a direct fit but what size tyres will be correct? There's 205/45R16 on them now. My car is a standard 3-Door currently with 15" Avus II with 195/65R15
I also assume my existing studs are okay to use.
Anyone have pics of the same VRS on a Mk4?
Offline viperjsy
Re: VRS alloys on Mk4?
« Reply #1 on: 30 June 2015, 04:00 »
thay will be 5x100 pcd
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 30 June 2015, 09:00 »
I think those tyre sizes are the standard Montreal sizes anyway so you'll be fine
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 14 July 2015, 22:11 »
When i read the title of this thread i was assuming you were referring to the 17'' VRS Octavia wheels which are commonly used on the mk4, i'm considering a set for my wagon as it happens.
For the 16'' version like you have the tyres should ideally be 205/55/16 as per fitted to the BBS Montreal2 wheels so you will find that the odometer will read over slightly along with a touch more arch gap and reduced ride height.
Offline Mr_Orange
« Reply #4 on: 20 July 2015, 19:02 »
Did you work out which bolts you need?
Build thread clicky
