Author Topic: Uprated coil packs and injectors  (Read 1475 times)
Offline PacalDnB
« on: 18 June 2015, 16:26 »
Hi all, what coil packs and injectors would you reccomend as an upgrade from the standard set on my 01 aum?
"It aint dubbin' if it aint rubbin"
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Uprated coil packs and injectors
« Reply #1 on: 18 June 2015, 20:03 »
if you go bigger injectors you will need a 3" MAF and a map to suit. You won't need it unless you're going bigger than a K03s though
As for coil packs you are probably entitled to a new set from VW, it's worth phoning your local dealers and asking. You can always change to the TFSI coilpacks, it would just mean you need to shell out for a set and also a set of spacers
Offline Dalo Harkin
« Reply #2 on: 23 June 2015, 12:55 »
Is there any benefit to the TFSI ones if the current ones aren't knackered?
