Author Topic: Lamda readings  (Read 2709 times)
Offline Ajay
Lamda readings
« on: 14 June 2015, 12:39 »
Hello,
Can anyone tell me if these lambda readings are normal
The problem I am having is that the car smells violently of fuel at idle and sometimes hesetates under high load, the throttle also bounces when coming back down to idle
Fault Codes that came up do not seem to be relevant here as they relate to the ABS - which wouldnt intefere with fuel management at Idle
p.s - its a 1999 AGU engine
Offline itavaltalainen
Re: Lamda readings
« Reply #1 on: 14 June 2015, 13:08 »
Can you do a proper log including MB7 for a drive. Only log MB1 and 7 so you have a reasonable sample rate and drive it for a few minutes when it's warm. Then upload LOG*.csv to a filehoster and post link here.
Offline Ajay
Re: Lamda readings
« Reply #2 on: 14 June 2015, 14:03 »
Yup - I can get that done - I'm guessing I can log using the free version? =/
« Last Edit: 14 June 2015, 14:21 by Ajay »
Re: Lamda readings
« Reply #3 on: 14 June 2015, 17:04 »
Lite version can do it if registered, unregistered I'm fairly sure not.
