Author Topic: Engine vibrations at idle  (Read 2491 times)
Offline Robbie89
« on: 13 June 2015, 00:57 »
Having intermittent random vibrations while engine is idling, feels like a misfire??
I noticed the engine is perfectly smooth again if I lightly hold the accelerater pedal down for an extra 1-200 revs.. Anyone else experience this? This is a new development currently at 16k miles
MK7 GTI
Offline GTI_Ant
Re: Engine vibrations at idle
« Reply #1 on: 13 June 2015, 22:15 »
Do you happen to have the climate control switched off?  I notice that when it's off the motor revs about 100rpm lower - feels a bit lumpier.  If there is a genuine misfire the engine management lamps will come on.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline GeoBog
« Reply #2 on: 13 June 2015, 23:46 »
Maybe one of the engine mounts giving away?
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
« Reply #3 on: 14 June 2015, 10:22 »
It does sound like a mount or a bush might be loose/broken, especially if it ties in with your other annoying rattle.
Have you done any violent launches or seen any warning lights flash up at any time?
Offline Robbie89
« Reply #4 on: 14 June 2015, 10:59 »
I don't do violent launches there's just no point with the crappy Bridgestones! :P
I did have the EPC light come on recently and went into limp mode for about 1 hour on and off?
MK7 GTI
« Reply #5 on: 14 June 2015, 13:56 »
Should be an easy dealer fix then as it'll be logged in the ECU.  :cool:
