Author Topic: Campaign Question  (Read 2015 times)
Offline The Hoax
Campaign Question
« on: 20 September 2005, 20:49 »
Hi Guys
I just bought a  Helios Blue Campaign to add to my growing fleet of 16v mark 2 and GLI cabby. I just can't help myself!
I have a quick and rather stupid question. I picked up the car and drove about 20 miles back home. On tick over when the car is warm, it still makes that brub brub brub noise of a car on full choke rather than a smooth tickover. It sounds as though it could be the automatic enrichment device not switching off.
Any ideas?
Thanks
Graham
Offline Tornado
Re: Campaign Question
« Reply #1 on: 20 September 2005, 23:43 »
It could be the automatic enrichment device not switching off! :evil:
Lower!
Offline The Hoax
« Reply #2 on: 21 September 2005, 00:02 »
Feck Off!!!
Offline Justins145bhpMK1
« Reply #3 on: 21 September 2005, 09:13 »
IS it standard engine wise?? No trick cams or anything??
Offline The Hoax
« Reply #4 on: 21 September 2005, 14:28 »
I think it is standard Justin but cannot be sure. Probably the easiest idea would be to run the car and check the MPG on the MFA, but I ain't even sure that the MFA works as I have only just got it and had no time to check it out.
I think with a high lift cam you get lumpy idling but this is a steady throb which sounds to me like overfuelling.
« Reply #5 on: 21 September 2005, 15:07 »
Almost like its hunting do you mean??? Guess you could try out all the usuals like cleaning out the throttle body, ISV etc. Check for any vacuum leaks etc? Worth a try.
Offline The Hoax
« Reply #6 on: 22 September 2005, 18:11 »
Cheers Justin - I'll give it a go.
The hoax
Offline Tornado
« Reply #7 on: 30 December 2005, 00:30 »
Maybe its the automatic enrichment device not switching off.
BRUB,BRUB,BRUB????????????????
Pished again?
Lower!
