Author Topic: rocker cover  (Read 1979 times)
Offline ean8
rocker cover
« on: 08 June 2015, 19:12 »
I have changed my rocker cover with the mk3 type one back in February  and ever since then its leaked i have had it off to check it but cant see any problems should i just order a new gasket and see what happens
Offline dragonfly
Re: rocker cover
« Reply #1 on: 08 June 2015, 19:18 »
Safe bet when replacing the rocker/cam cover to replace the gasket.  They don't cost a lot.
Offline Steve_B
Re: rocker cover
« Reply #2 on: 09 June 2015, 22:54 »
Have you switched over to a rubber gasket as well and not changed the studs? Need ones without the shoulder if using the rubber gasket that has metal collars around the holes.
Offline Brighouse-gti
Re: rocker cover
« Reply #3 on: 10 June 2015, 19:53 »
Lol, I did the very same thing a few month back. Rather than paying out for another gasket, I just removed the metal rings from the mk3 gasket, fits a treat. As mad as it sounds, put a dab of oil on your finger and lightly oil the gasket before you bolt it all bk down (15ft/lbs ;-}) as it helps seal it all back up!
