Author Topic: Wont start up!  (Read 2683 times)
Offline Raj-Mk2-Gti
Wont start up!
« on: 07 June 2015, 15:34 »
Ok,whilst driving along the road yesterday the car was losing power and then the engine decided to turn off. after i was unable to start up. It has a fitted immobiliser which works fine. All levels including oil, water were all topped up. plenty of fuel in the car also and battery is fine too. Really is a mystery after the car has just recently had a service done. HELP?
Offline Andy-H
Re: Wont start up!
« Reply #1 on: 07 June 2015, 19:10 »
Can you hear the fuel pump priming when you turn the ignition on?
Is it 8v or 16v?
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline Raj-Mk2-Gti
Re: Wont start up!
« Reply #2 on: 07 June 2015, 22:39 »
Yeah i can hear the fuel pump priming after I've turned the key and pressed the immobiliser button. However, this isn't always the case. Sometimes i have take the key out and repeat this process a few times to hear it. Could it be the immobiliser thats causing the issue? Its an 8V.
Work i have had done to car regarding the start up problem and the idling:
New Leads
Plugs
Coil Pack
Distributor
Fuel Pipe
Recent General Service
Unfortunately I'm not that mechanically minded, reason for me sending an SOS out.
Car needs to get sorted before GTI International.
Contact me if anybody wants to have a chat: 07860931099
Thanks
Offline Andy-H
Re: Wont start up!
« Reply #3 on: 08 June 2015, 07:05 »
When the immobiliser doesn't cancel, does the car turn over? If it does then I don't think it'll be that.
Have you taken a spark plug out and turned it over to see if you're getting a spark?
'91 Tornado red Mk2
Offline dragonfly
Re: Wont start up!
« Reply #4 on: 08 June 2015, 19:21 »
Have you checked the wiring on the ignition? It's not uncommon for the wiring to have been butchered to install alarms and immobilisers.  Who fitted the immobiliser?
Offline Sgt_Lemon
  • 8v owners club
Re: Wont start up!
« Reply #5 on: 09 June 2015, 17:22 »
Fuel pump working? Both of them
Offline Mr Blue
Re: Wont start up!
« Reply #6 on: 09 June 2015, 21:48 »
Lift pump suspected.
Offline Raj-Mk2-Gti
Re: Wont start up!
« Reply #7 on: 09 June 2015, 23:52 »
Hi all,
Yes i have taken the spark plug out and checked it and it seems fine. when i brought the car it came with the immobiliser fitted but unable to trace the paperwork on it so i don't know who fitted it. The ignition wiring i haven't checked yet but will have it looked at. The fuel pump is fine too. I'm having the vehicle looked at over the weekend and hopefully we can get it sorted. ill keep you posted!  :wink:
Thanks
