Author Topic: Air Recirculation turning off by itself  (Read 4611 times)
Offline GeoBog
« on: 06 June 2015, 21:02 »
Couldn't find anything related around here nor on the mk7 forum so has anyone noticed or had this issue? Basically, each time I am turning on the engine and I press the air recirculation button, the amber light comes on as usual then in the next second it turns off. If I press again on the button, the light turns on again and stays like that until I press the button again to turn it off (as you would expect to work anyway). Just to mention that the automatic recirculation option is unticked so no reason why it would automatically switch off by itself.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline ajmoir36
Re: Air Recirculation turning off by itself
« Reply #1 on: 06 June 2015, 21:44 »
There is something about auto recirc and reverse cant remember what it is though.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline GeoBog
« Reply #2 on: 07 June 2015, 00:32 »
It's got nothing to do with reverse. It does it even when driving, let's say I start the engine and I drive off for a while and then push the button to activate recirculation. The led goes on for a sec and then goes off. If I press it the second time it stays on and the recirculation is enabled until I turn it off from the button.
2020 VW T-Cross SEL
Offline monkeyhanger
« Reply #3 on: 07 June 2015, 07:47 »
My recirc goes on first time and stays on.
Offline itavaltalainen
« Reply #4 on: 07 June 2015, 11:55 »
So does mine, does it give you any indication in the touch screen why it may turn it off again?
The thing about revers and recirculation is just the other way round - it is turned on while you reverse if it is not already. They introduced this so you would not suck in your own exhaust fumes when reversing ;)
Offline GeoBog
« Reply #5 on: 07 June 2015, 12:13 »
No indication on the screen, just the amber confirmation LED below the button.
2020 VW T-Cross SEL
Offline GrahamFR
« Reply #6 on: 08 June 2015, 09:09 »
mine does this, I then have to push it again and it stays on, never knew why, probably never gonna :huh:
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline GeoBog
« Reply #7 on: 08 June 2015, 12:45 »
Thanks for confirming this Graham. At least I know that my climate control is not broken, but it looks like a general behaviour of the mk7.
2020 VW T-Cross SEL
Offline dereks
« Reply #8 on: 08 June 2015, 15:47 »
Hmm.. Mines does this as well I blamed the wife :laugh:
« Reply #9 on: 08 June 2015, 21:00 »
Even if you go into the setup?
