Author Topic: rob119 - mk2 vr6  (Read 31871 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: rob119 - mk2 vr6
« Reply #10 on: 24 November 2005, 18:58 »
small update
took driveshafts out the other night when my mate brought few tools for me to borrow
so there off ready for gti shafts to be put on when engine is sat in place
got the power steering pipe unbolted from the rack eventually
bolt was totally screwed got the new pipes bolted in place now
so i can crack on with it now
the engine should be sat in place on the weekend and hopefully
runnin next week once i get a few bits and pieces sorted out
as i have to get the clutch bracket sorted but i can do that last
pictures soon to follow.............
Offline VR6_ROB
« Reply #11 on: 07 February 2006, 18:36 »
big hold up
for a long time now
saving money for the paint as i thought i may aswell get the paintwork done first
so need to save 800quid up
getting inside and out done
and engine bay all in blue
then once thats done I can carry on, taking to long for my liking
getitng help for putting the engine in
i can fit the new steering rack in and few other bits n bobs
then everything else will be a secret once its running but I have a few bits
and pieces waiting at home ready to fit
Offline VR6_ROB
« Reply #12 on: 09 April 2006, 20:58 »
just ordered
corrado front end
radiator fans and crossmember and radiator suppor dont know if thats seperate though
been neglecting the car for a long time
not had time and been fed up of it
think i may possibly need a power steering pipe as one of them is
crossthreaded but i will have to check them first
once parts arrive i can crack on
Offline VR6_ROB
« Reply #13 on: 14 July 2006, 21:17 »
i think i should make a update now
all engine bays painted apart from the back because it did not need it
painted brake servo
fitted the corrado crossmember and slapped the engine in today
put wheels back on and fitted new power steering rack to
heres a pic of what it looks like to
Offline VR6_ROB
« Reply #14 on: 22 July 2006, 13:55 »
i took a couple more pics today
getting put back together
all thats left to do really is
the brakes need uprating
decat pipe fitting
cable change and clutch bracket
and just other few bits and bobs
Offline VR6_ROB
« Reply #15 on: 30 July 2006, 13:13 »
hey all car is all up and running now
took nearly a year lol
had a blast in it yesterday efore it goes back in garage
save up for bodywork and my god!!!! its so dam fast
got few niggles to sort out like ome lights dont work
tidy up bit of wiring and fuel pump constantly spins when imobilizer goes off
because they only come on for second usually
im using the gti fan and radiator which is flipped sat different
but im going for the corrado fans and radiator when i get hold of them
as the engine feels so dam hot but the temp is quarter when fan kicks in which
keeps it cool but not cool enough for me ill get some pics later on
Offline VR6_ROB
« Reply #16 on: 01 August 2006, 21:46 »
here is a few more pics of my motor enjoy
Offline VR6_ROB
« Reply #17 on: 07 August 2006, 11:18 »
cars booked in for bodywork
got my sprinter vent today through the post
just awaiting a few other bits n pieces
ripped all inside out apart from the dash
cleaned and dyed my carpets so they are jet black again
also redone underneath the carpet
with big roll of underlay i found lying about in garage loft
small problem with lights one light keeps blowing fuses so i gotta try sort that out
Offline VR6_ROB
« Reply #18 on: 03 September 2006, 16:29 »
car is now in the bodyshop
getting full respray still in white apart from engine bay
and inside the car as inside is still good and i did engine bay before engine went in
i popped up otherday to see the car
and it seems brake fluid is all over the floor
so that has to be sorted once its all painted
pic to follow soon but will look nearly complete
Offline VR6_ROB
« Reply #19 on: 23 September 2006, 17:55 »
right here is some more pics i taken earlier on
this is picture fo the rear you can see tow eye is flushed out and the rear badge
i got round the window painted instead of buying a new sticker as they cost quite a bit
closer view of where tow eye used to be
had bonnet modified so engine does not rub as i aint fitted corrado rear mounts on the engine
here is a better view of the sprinter vent
the wing has been filled where aireal used to be and had mirrors colour coded
just pic of car with spoiler back on it
here is a pic of the engine its dirty and needs tidying up job for next week
and how it is at the moment dont want it getting dusty now
