Author Topic: Mk4 golf boost problem  (Read 1545 times)
Offline Cnc1994
« on: 06 June 2015, 14:11 »
I had a boost problem it was building up and dropping on the gauge, pressure tested system to find a small pipe on the bottom of the intake manifold split I replaced it today and found a pipe not connected, just wounding if anyone has any info/pictures the pipe that isn't connected to anything has part number 058103247 can anyone help on where it connects to?
Offline WadGTI
  • Golf GTI'er
Re: Mk4 golf boost problem
« Reply #1 on: 06 June 2015, 19:30 »
That part no for the oil breather system. The pcv valve sits inside that and connects the upper hose to the crankcase.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 06 June 2015, 19:45 »
Can you get some pics for us mate? Will make it easier to tell you where the pipe should go. Also what engine code?
