Author Topic: vag com coding  (Read 2948 times)
Offline gareth_iowc
vag com coding
« on: 05 June 2015, 00:08 »
hi guys.
so i have put a 1.8t in my mk3 and she runs and drives sweet.
i have a few errors on my ecu for parts that are missing from the mk4 and wondered if i can code them out?
17834/P1426/005158 - EVAP Purge Valve (N80): Open Circuit
18084/P1676/005750 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
17931/P1523/005411 - Crash Signal from Airbag Controller: Implausible Signal
18057/P1649/005705 - Powertrain Data Bus: Missing Message from ABS Controller
cheers
Offline N900 MJT
Re: vag com coding
« Reply #1 on: 23 June 2015, 15:03 »
Most of the time you will need to just put a resister into the open plug to get rid of the codes, you cant code them out with vagcom as far as I know
