Author Topic: Engine swap  (Read 4134 times)
Offline Jasonniemand
Engine swap
« on: 02 June 2015, 05:01 »
Hi,
Im wanting to do a agg engine swap in a 1990 mk2! Just want to know if any additional engine mounts are needed or anything els! Like the wiring harness and additional parts to complete the swap.
Offline Simeon
Re: Engine swap
« Reply #1 on: 02 June 2015, 05:18 »
If your engine is currently a 1.8 8v then it'll bolt straight in and run as long as you use the adaptor on the distributor.
Re: Engine swap
« Reply #2 on: 02 June 2015, 14:10 »
Cheers man, and regards to the wiring harness, whats the go with that? Is it a straight plug n play or do you have to install the complete agg engine wiring harness, and if so is it a complex task?
Regards
Offline Simeon
Re: Engine swap
« Reply #3 on: 02 June 2015, 16:21 »
I presume you already have an 8v gti then? If so the usual swap is to use the AGG/2E bottom end, refurb your current cylinder head and fit it to the 2litre block using the AGG/2E headgasket. Then use all the existing ancillaries off your current engine and drop it in - straight swap :) Do a quick search on your favourite search engine and there's loads of info on the distributor mod you have to do, but very straightforward.
If you don't currently have an 8v gti then you will need the whole lot from the mk3, wiring loom included. I presume your car is CE2 (is the hazard switch on the column?) so the wiring will pretty much plug straight in. Again, easy swap, but if you're doing a full engine conversion then you might as well go for something with a bit more poke, like an ABF. If you don't like 16vs then stick a G60 in it ;)
Edit; If you currently have a carb engine, either 1.6 or 1.8 then you can grab yourself a webber carb and block the injection holes in the head, think a 1p coin is a good fit. Not going to be as fuel efficient or powerful as a full injection swap, but should give a bit more poke for little effort.
« Last Edit: 02 June 2015, 16:24 by Simeon »
Offline gazareth
Re: Engine swap
« Reply #4 on: 02 June 2015, 22:34 »
if you use 2 litre bottom end with carb you would need an electric fuel pump as the 2 litre auxiliary shaft has no lobe to drive the mechanical pump.
Re: Engine swap
« Reply #5 on: 02 June 2015, 23:58 »
what is the difference when fitting the current cylinder head onto the 2.0L block? or can you just stick with the current cylinder head on the AGG engine. Ok, well if i was to go with an ABF, is there any major changes in regards to the engine mounts and again will the wiring harness in this situation be a straight plug n play?? :smiley:
Offline gazareth
Re: Engine swap
« Reply #6 on: 03 June 2015, 00:53 »
you need to tell us if the car is a gti or not???
Re: Engine swap
« Reply #7 on: 03 June 2015, 02:31 »
sorry, yes its a 1990 mk2 1.8 8v gti!
Offline Simeon
Re: Engine swap
« Reply #8 on: 03 June 2015, 04:00 »
Cylinder head is your choice, both fit.
Abf is a more involved swap as you need wiring loom etc. Physically mounts the same though and you can use your existing gearbox. Best bet is to have a search on the internet, both swaps are heavily documented and explained.
You should be able to get a full abf conversion for about 2-300 quid, maybe a bit more if it is low mileage and includes gearbox etc.
Re: Engine swap
« Reply #9 on: 03 June 2015, 05:31 »
ok thanks, and in regards to the wiring loom, how difficult will it be to put the abf engine wiring loom in? Also will there be any additional parts required for the abf swap?
