Author Topic: Weird idle issue  (Read 2816 times)
Offline Exardious
Weird idle issue
« on: 01 June 2015, 14:43 »
Hey all
So i have a small issue with my idle. When i start the car from cold, idle is fine. If i then drive to or from work, which is a 15 min. drive, and i arrive at my destination, my idle is just horrible. It splutters and stutters. But if i then turn of the ignition, and start the car again, the idle is fine again.
Any ideas whats going on? :sad:
Offline itavaltalainen
Re: Weird idle issue
« Reply #1 on: 01 June 2015, 17:18 »
Which engine (code)?
Offline Exardious
« Reply #2 on: 01 June 2015, 19:47 »
Oh yeah of course. It's an ABF. 1994 golf. Bone stock.
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 01 June 2015, 20:28 »
Remove the isv ,clean it out with some petrol or carb cleaner,it may just be getting stuck.
Offline Exardious
« Reply #4 on: 01 June 2015, 20:40 »
Could A faulty / stuck ISV affect mpg? I'm getting dreadfull economy. 24mpg avarage brim to brim
« Reply #5 on: 01 June 2015, 21:23 »
At 24mpg I would suspect something else is happening. What's VCDS saying?
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 01 June 2015, 23:23 »
I would guess your temp sensor for the ecu is knackered,telling the ecu the engine is still cold when it is warmed up,but get it scanned for fault codes first before changing any parts,i used to get around 40mpg on my abf
Offline Simeon
« Reply #7 on: 02 June 2015, 05:23 »
I'd agree with the above on the ECU temp sensor, either that or the lambda sensor. Temp sensor is cheap and easy to replace so stick one in if you can't scan it for codes.
