Author Topic: 1.8t tuning  (Read 2888 times)
Offline Screech16v
  • MK3 20vt AGU
1.8t tuning
« on: 27 May 2015, 21:41 »
May be a daft question but......  will an AUM small port intake including aum injectors which I believe are 318cc work with my agu,the injectors have the same plug ev6,agu are 205cc I think ,it seems like an easy way to get larger injectors before a stage two remap,this aum engine is broken and im seeing what I can utilise for free. thoughts anyone?
Offline Screech16v
  • MK3 20vt AGU
Re: 1.8t tuning
« Reply #1 on: 27 May 2015, 21:57 »
Adding to this I see the general opinion is a large port doesn't aid until you are running big numbers,is there any truth in this?
Would these seats fit in my agu manifold thus allowing me to fit the aum injector? cheers
http://www.ebay.co.uk/itm/GENUINE-SEAT-LEON-CUPRA-LCR-IBIZA-1-8T-INJECTOR-INSERTS-SET-OF-4-/181756878894?pt=LH_DefaultDomain_3&hash=item2a518de02e
« Last Edit: 27 May 2015, 22:46 by Screech16v »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 1.8t tuning
« Reply #2 on: 28 May 2015, 14:19 »
AGU runs different impedance through the injectors so no they aren't just plug and play unfortunately
Offline Screech16v
  • MK3 20vt AGU
Re: 1.8t tuning
« Reply #3 on: 28 May 2015, 23:05 »
POOP! Cheers wazzer,do you know what impedance I need ,14.5ohms by any chance?
Any thoughts on these?
http://www.ebay.co.uk/itm/191588121021?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline Chris.
Re: 1.8t tuning
« Reply #4 on: 28 May 2015, 23:23 »
They wont work.
EV1? FAt stubby type.  Calibra yellows or saab reds.
Click For Build Thread
Offline Screech16v
  • MK3 20vt AGU
Re: 1.8t tuning
« Reply #5 on: 28 May 2015, 23:35 »
Hi chris,so the ebay ones no good? I think they look too short and wont reach anyway without mods to the fuel rail or mani
Offline Screech16v
  • MK3 20vt AGU
« Last Edit: 29 May 2015, 00:05 by Screech16v »
Offline shaft69
Re: 1.8t tuning
« Reply #7 on: 29 May 2015, 08:32 »
Sure are.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 1.8t tuning
« Reply #8 on: 29 May 2015, 14:38 »
If you're sticking with the K03s I would probably say the yellows will be enough, K04 the reds. Best to check with whoever is mapping it first though...
Offline Screech16v
  • MK3 20vt AGU
Re: 1.8t tuning
« Reply #9 on: 03 June 2015, 19:50 »
Thanks guys,ive got a set of bosch reds on route,318cc same dimensions as agu direct fit
