Author Topic: jack plugs help  (Read 2606 times)
Offline dan0908
jack plugs help
« on: 26 May 2015, 10:17 »
Hi I'm new to the forum and was looking for advice on my mk 4 1.8t project (hopefully be finished in time for MIVW) as I've delocked the entire car currently if the battery goes flat I'm screwed so I'm gonna make up a couple of battery cables and connect them to a jack lead then and then make up some jump leads to a jack plug just need some recommendations for jack plugs and cable to use is it the 175 amp plugs or the 50A and what size cable standard battery cable I would have thought should be fine any help you guys have would be much appreciated thanks
