Author Topic: Unleaded vs Super unleaded  (Read 15069 times)
Offline benmartingolf
« on: 20 May 2015, 20:51 »
Hi all,
I hopefully pick up the new motor next week and I know the GTI can run on just unleaded but are there any disadvantages to using it or advantages to using super unleaded?
Some people say you can get better fuel economy with the super unleaded but does anyone see any major differences either way?
Thanks, Ben
Collect 28th May 2015
GTI MK7, Pure White, 5 Door, DSG, Performance Pack, Discover Pro, Dynaudio, Keyless
Offline barrym381
Re: Unleaded vs Super unleaded
« Reply #1 on: 20 May 2015, 20:59 »
if I was buying a new gti it would get the super unleaded as extra cost per tank is minimal  :smiley:
« Reply #2 on: 20 May 2015, 21:09 »
I think il try to use super unleaded as i think even though you can use unleaded super unleaded is recommended. But I just didn't know if anyone saw any differences.
Offline monkeyhanger
« Reply #3 on: 20 May 2015, 21:39 »
But it is set up for RON95. It won't be able to benefit from RON98 fuel like the R can. Extra cost per tank minimal? 9% more, for perhaps a slightly better set of detergents and no mpg gains - throwing money away. If the GTI could run appreciably better on RON98 then VW would be recommending it.
Running an R on RON95 will be a false economy though - it will be running more efficiently on RON98, your 10p/L savings buying RON95 will be negated with lower mpg as the car ends up igniting it earlier than it would like to avoid pinking.
Contrary to popular belief, RON98 isn't any more calorific than RON95, it is less volatile so it can be squeezed further  (greater compression ratio, or same compression ratio at a higher operating temp) without pinking before it is intentionally ignited by the spark plug. Running a RON95 optimised car on RON98 fuel just means that the fuel isn't being compressed to its full potential before ignition and at best will ignite in the same way as RON95, at worst you could get an incomplete burn (unlikely, as petrol of both types have a low flash point). The only obvious advantage then is running a tank through for any detergent cleaning benefits.
Offline 2014GTi
  • Das Auto
« Reply #4 on: 20 May 2015, 22:40 »
Most modern cars have adaptive ECU's (learning) which monitors the quality of fuel in the tank, after 2 - 3 tank fulls of Super Unleaded you'll notice the difference, it also keeps the engine clean.
I have been using Shell Optimax, V-Power and Nitro since 2000 in various cars and its worth paying the extra few £££'s per tank full in my opinion.  :cool:
2014 Volkswagen Golf GTi
2004 Volkswagen Golf R32
2011 Volkswagen Polo Bluemotion
2001 SEAT Arosa TDi S
1999 John Cooper Mini Works S
2005 Vauxhall Astra SRI CDTi
2002 Audi S3 quattro
1999 Peugeot 206 Grand Tourisme
Offline mk7gti
« Reply #5 on: 20 May 2015, 23:35 »
Save the cash. This is from my GTI manual:
« Last Edit: 20 May 2015, 23:38 by mk7gti »
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
« Reply #6 on: 20 May 2015, 23:55 »
Il be taking the manual to bed when I get it. A little bedtime reading. From what I remember its always been an interesting debate.
The difference at the pumps is around 5p per litre i think.
« Reply #7 on: 21 May 2015, 06:06 »
Around 10p a litre like for like around me. Shell RON95 = around 114p/L, shell 99 = 124p/L. I can get Esso/Tesco 99 for around 120p/L if I shop around, so that 5 or 6p difference is comparing Esso Supreme 97 to Shell Vpower 99.
« Last Edit: 21 May 2015, 06:19 by monkeyhanger »
« Reply #8 on: 21 May 2015, 06:17 »
Cleaner car, for 10p/L? Possibly/likely. Placebo effect? Very likely. A RON 95 optimised car won't advance the timing to take advantage of RON98/99, but a RON98 optimised car will retard the timing to run RON95 without pinking. Smart timing alteration is designed to adapt to the use of lower quality fuel than is desired, due to lack of availability, not to make the car overperform when given a diet of higher RON fuel. In previous years between 2000 and now, VW were optimising certain cars (including the GTI) that sat below the R32 and were optimised for RON98.
At the end of the day it's your money.  :whistle:
Offline mcmaddy
« Reply #9 on: 21 May 2015, 07:09 »
Matt your wasting your time explaining it. Placebo effect will always win over scientific knowledge  :wink:
