Golf mk4
Wazzzer
ko4 upgrade??
Topic: ko4 upgrade?? (Read 1940 times)
rupture
ko4 upgrade??
19 May 2015, 22:37 »
Alright folks. I've got my mk4 running a slightly modified stock lump (filter, forge d/V, Cat back exhaust etc.) And was wondering if I wanted to put a ko4 off a 225tt in place of my ko3s, would I have to change the injectors/rail, manifold etc and how much works involved??
shaft69
Re: ko4 upgrade??
21 May 2015, 21:20 »
I have pull k04 kit forsale you need manifold, turbo, downpipe, inj, oil/fuel lines, tip, maf housing and map. Easy fit and leaves ko3 powered 20v for dead.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Chris.
Re: ko4 upgrade??
25 May 2015, 01:58 »
Wouldnt say leave it for dead. Well tunes k03s and a k04-023 there will only be 30bhp peak bhp or so in it.
If you have the full k03* mods for stage 2, id push for a stage 2 k03s. But if your money allows and can get EVERYTHING cheap for k04, then go k04.
If thinking of buying a k04-023 and then buying add ons to make a 023 fast....consider a TFSI K04-064. Then you leave most cars for dead on the road.
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: ko4 upgrade??
25 May 2015, 12:04 »
As you are finding out Chris?
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Chris.
Re: ko4 upgrade??
25 May 2015, 12:15 »
oh yes
Golf mk4
Wazzzer
ko4 upgrade??
