Author Topic: The big puzzle!  (Read 2626 times)
Offline Ajay
The big puzzle!
« on: 16 May 2015, 23:53 »
Hey folks
So, finally got a VAG scanner and I plugged it in hoping to find all sorts of answers...
The car: 1991 Karman with a 1.8T AGU engine (1999?)
The issue: Anti-stall kicks in every single time the revs drop to idle - the car is almost dying at every opportunity, or clinging on to life, depending on how you look at it.
According to VAG:
Error: something like Canister Purge Regulator Valve (N80) open output ?
Also has a vehicle speed & ABS error - neither of which I am worried about as my setup has neither present
Maf sensor reads abot 3g/s at idle, seems to behave normally when it revs higher
Temp sensor - readings look very plausable - hot when its been running, cooler when it's just been started. Someone said about dual circut on another thread, which may make sense as there's 2 temp readings? one that moves and the other stays at 29-30 degrees
Lambda - it says something like 20%???? at idle and dissapears to near nothing/normal when you rev it a bit... and STINKS of fuel...
Ideas?
Offline WadGTI
  • Golf GTI'er
Re: The big puzzle!
« Reply #1 on: 18 May 2015, 13:11 »
I would start at the fault you picked up.
According to VAG:
Sure this valve regulates the fuel vapour pressure from the tank and more so on idle? Someone else might be able to explain in more detail.
Offline Ajay
Re: The big puzzle!
« Reply #2 on: 19 May 2015, 10:57 »
I'm sure the canister doesn't actually exist on the car now though as I was unable to locate it in the engine bay =/
Offline WadGTI
  • Golf GTI'er
Re: The big puzzle!
« Reply #3 on: 19 May 2015, 11:44 »
check the diagram from vagcat and reaplce whats missing. Not having the canister means you are venting fuel vapour into the bay??(assuming the breather pipes are still there)
Offline Mr_Orange
Re: The big puzzle!
« Reply #4 on: 20 May 2015, 18:10 »
Engine transplant may have left the connector loose on the loom somewhere, without the vapour system rigged up back to fuel tank. Find the offending plug and trick the Ecu with a suitable resistor ;)
Build thread clicky
Offline Ajay
Re: The big puzzle!
« Reply #5 on: 21 May 2015, 12:01 »
do you think that would cause an uneasy idle?
Offline Chris.
Re: The big puzzle!
« Reply #6 on: 25 May 2015, 02:00 »
Charcoal canister would bear no ill effects on a engines performance or idle.
Sounds like a pipe is split or missed on somewhere,
Fuel trims block 032 in VCDS sounds bad.   shouldnt be anywhere near that.  Investigate further on fuelling side....especially before booting it.
Click For Build Thread
Offline Ajay
Re: The big puzzle!
« Reply #7 on: 10 June 2015, 10:12 »
Anyone have any more thoughts on the lamda reading? I assume it affects fuel flow..??
Offline Dalo Harkin
Re: The big puzzle!
« Reply #8 on: 10 June 2015, 12:54 »
vehicle speed sensor I would assume is like the one that went on mine, the car would just all of a sudden die when stationary (revs drop) and would struggle to start again.
For how much they are I would replace that
From memory there are 3 blocks under in the inlet manifold, one is brown, one white and one black I think, pretty sure the brown block leads to the speed sensor
