Author Topic: fault code help  (Read 2130 times)
Offline BEELZEDUB
fault code help
« on: 16 May 2015, 09:29 »
just read the codes on my wifes mk4 1.8t agu code and got these codes on VCDS
00544 - maximum boost pressure exceeded 35-10 intermittent
00561 - mixture adaptation 14-00 adaptation limit (add) exceeded
00515 - camshaft position (hall) sensor (g40) 30-10 - open or short to plus - intermittent
had to fit a new turbo about 3 months ago and it has crazy surging almost like its hitting a rev limiter. if you back off the gas you can then drive it gently past the hesitation.
it had this problem when we bought this car about 4 years ago then on day the problem went, after looking at the fubar'ed turbo that came off i would say the boost was able to escape via multiple cracks in the exhaust housing so cured the over boost. now we have a new turbo genuine not cheap chinese one the problem is back and i dont want to break this one.
any ideas?????
this week the car has started to hunt on idle so rescanned and got the bottom 2 codes, so guess its either the sensor breaking down or bad wiring again any ideas???
thanks Mike.
« Last Edit: 16 May 2015, 10:11 by BEELZEDUB »
Offline BEELZEDUB
Re: fault code help
« Reply #1 on: 17 May 2015, 14:49 »
anyone?????
Offline baker1983
Re: fault code help
« Reply #2 on: 17 May 2015, 15:04 »
Triple check all vacuum lines!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: fault code help
« Reply #3 on: 17 May 2015, 21:21 »
Have you cleared the codes and checked again?
Offline BEELZEDUB
Re: fault code help
« Reply #4 on: 18 May 2015, 23:21 »
yes did that and they all came back again..
