Author Topic: 2 Step Anti Lag Map?????  (Read 2421 times)
Offline PacalDnB
« on: 15 May 2015, 21:11 »
Can someone please explain what the 2 step map is?
"It aint dubbin' if it aint rubbin"
Offline rockmonkey69
Re: 2 Step Anti Lag Map?????
« Reply #1 on: 16 May 2015, 11:41 »
I'm guessing you mean the launch control mapping available to those on the later 1.8t ECU, in which case it's a second limiter - whatever rpm this is mapped to, mine is set to 4500rpm, which activates when your foot is on the clutch and you're stationary, negative timing is also thrown in. This all keeps the turbo spinning to build boost and hold revs at the pre-set rpm ready for the car to launch off the line.
There's a lot of fireworks that come with it all, detrimental to many components, especially the turbo. I found it absolutely useless on fwd chassis.
Offline Chris.
« Reply #2 on: 25 May 2015, 02:03 »
Useless on all mk4s really IMHO.  Rockmonkey has it just about summed up.  It'll kill a engine in no time...and your turbo.
Learn to launch a FWD car properly would be my advice.
Click For Build Thread
« Reply #3 on: 25 May 2015, 12:10 »
It will certainly be interesting to see when I get a chance to test the launch on the golf, I'm expecting 0-60 to be in the region of 2-3 seconds, something I wouldn't be able to achieve on road tyres with my previous setup.
